What next?
WSC-SHO
SHO Groupie
Nebraska
Well, after almost a year of weekend work, I finally feel confident enough to take the black SHO out for an AutoX event. What I've done to it so far:
-Intrax/Sensatracs
-New Strut Rod Bushing (frt and rear)
-New AL SFB's
-New swaybar links and bushings
-CPS and crank seal replaced.
I'm also planning on new tires as soon as money allows, thinking Hankook RS3's or Potenza's. Wheel is a 17x7 if anyone has any other suggestions.
My question is, what should I do next? I've been looking into making my own sub frame connectors because I own a welder, but don't really know where to start. Also been looking at changing the front swaybar to a 20.6 from the current 24mm to prevent it from pushing in corners, although some of that may clear up with better tires.
How much would strut tower braces and an H brace stiffen the chassis?
Basically just talk chassis stiffening, if you were going to Auto X it.
Thanks in advance!
Tim.
:thankyou:
SHOspazz92
Banned
Triad Area, North Carolina.
Go out and drive the car as is. Make assessment on how the car drove. Come back, ask question again.
That way, when you come back and say "The car would not do this" or "I want it to do this", We can give you a more specific answer.
-Sam
WSC-SHO
SHO Groupie
Nebraska
Cool, thanks for the suggestions guys, anyone know where I can get a wrench to tighten that nut? :laugh_ti:
Any suggestions for a good, grippy Auto X tire?
zblackbeast
SHOtarded
Omaha, NE
It handles really well.. i havent gotten any drive time behind the wheel and its got really ****** tires on it right now, so its hard to tell the real limits... But like all SHO's ive driven its got understeer
WSC-SHO
SHO Groupie
Nebraska
I remember seeing a picture of someone who had made or bought an H-Brace that wasn't the milled Keystone one. Anyone have a picture of it? I think it was white...
fdogg96
SHOCal Member
Southern California
Gen 3 subframe bushings. Yes, get he H-brace and strut tower braces. Get adjustable end links and adjustable control arms too.
NP SHO
Rice Killaaa
Windsor, New York
Why would he go with Gen 3 subframe bushings when he has recently installed new ALSFB? Wouldn't that be downgrading in a way?
Wait... were you talking about bushings, or a Gen 3 subframe swap?
WSC-SHO
SHO Groupie
Nebraska
A Gen III Subframe swap may be a little out of my league at the moment, but It's on the list for sure.
What year GTP arms do people use? And what do you mean by adjustable endlinks? Swaybar endlinks?
zblackbeast
SHOtarded
Omaha, NE
Run a search bud.. ill let u know if I find it first I think it was the later gtp.. I know ghe early 90s gps had a mono leaf rear suspenson so idk the control arm set up went
WSC-SHO
SHO Groupie
Nebraska
Thanks Clay, and I figured out the adjustable endlinks question. Those are pretty trick but Yikes! that price...:omg:
zblackbeast
SHOtarded
Omaha, NE
Yeah... But considering the adjustment you can make in the rear, and the $$ you'll save from not having to buy tires every 15k is worth it
jayro
Auburn, In
I would say disconnect your front sway bar until you can change the set up to a 20 up front and a 26 out back. I really noticed a difference when I added subframe connectors. Star specs do very well for autox. You can also get a different alignment.
Drive it and report back. If you are running the stock diff remember not to stab the throttle coming out of the corners or you will just light up the inside tire. Have fun.
LOUDSHO92
Rancho Cucamonga, CA
I would highly suggest subframe connectors.
The years for the GTP are listed but you need the correct spacers and washers. SHONut no longer sells them. You also need to pull them from 2 different cars.
For the time and trouble to find them and the hardware, I think the Ingalls are worth it: SHO Source
I am not sure what you mean by milled for the h-brace. They are welded together.
Coilovers would be the next step: SHO Source
