Mafs
bubba
ATX Connoisseur
Fort Wayne, Indiana
Here's the thing, I changed my maf back to the stock 55mm, and the car ran like ****, so I changed it back to the t-bird maf... Car is back to running great. I'm stumped aobut this. Is it possible that the car likes to run a little bit rich, I'm not sure how long it's run rich, but it seems to like it?
Or is the 55mm maf bad that I put on? After the maf change, I unplugged it and the thing just stumbled 4k on, the thing couldn't a wouldn't get out of it's own way!
theman88b
SHO Me TheMoney
Colorado
Does the 55mm have a different sensor? Or are you using the same sensor just different size MAF's? You also have to let you car relearn after a change like that. Try resetting the ecu after you change it.
yamahaSHO
E85 whore
Arkansas
Are you clearing the PCM? What is the curve for each MAF and is it accounted for with some sort of tuning?
bubba
ATX Connoisseur
Fort Wayne, Indiana
Yeah I've cleared for both, sensor is the 55mm and whatever came with the 70mm. Here's the thing, 55mm, the thing is good in the first 2 gears, it pulls good, then I shift into 3rd grear and it feels like I hit a wall. I put the pedal all the way thru the floor, and the rpms don't come up at all, very fast or even somewhat fast.
yamahaSHO
E85 whore
Arkansas
Sounds like you have a malfunction. Have you logged with a WBO2 or any data logging?
vortex2450
Buying Parts...
North Carolina
I have a similar issue as my car came with a 93' cobra MAF and untuned ECU. I changed out for a stock MAF and the car stumbled and ran like crap even after a reset, so I reinstalled the Cobra MAF and it's was fine.. maybe these cars have amind of their own after all.
yamahaSHO
E85 whore
Arkansas
Since the cars came with these MAF's... Have you both verified that you don't have a chip in the ECU?
jimtash
nc
Put the 55 back on and do a KOER test. Then tell us the results. More than likely the sensor is calibrated wrong and your 02's are cutting back on the mixture at WOT.
