Axle replacement
NEp8ntballer
cyber ninja
fifth circle of ****
I'm gonna be replacing my passenger side CV axle tomorrow and I'm wondering if I'll be needing to rent a slide hammer to get it out or if I'll need anything other than the appropriate sockets, wrenches, and a long piece of metal to separate the balljoint from the knuckle.
yamahaSHO
E85 whore
Arkansas
You should be able to pull it out of the transmission by hand, especially if you have a replacement. A jack handle should do fine to lower the control arm.
firebat45
Edmonton
You don't need a slide hammer. You can tap the axle out of the intermediate shaft with a chunk of wood/brass and a hammer, and use a puller, hammer with brass/wood, or air hammer with a pointy tip to push the axle out of the hub.
yamahaSHO
E85 whore
Arkansas
Replace "transmission" with "intermediate shaft". You should be able to pull it out by hand or with firebat45's method.
