100 shot.
AREA 91
Area 91
Come on guy's, everyone know's that you can't run a 100 shot on a SHO. You'll blow the welds on the intake!
:swing:
Art5
white plains, NY
I ran wet shot before and didn't blow no welds off anything. I didn't spray it right though.
zach44102
BIG TURBO
Georgia
ummm on a sho engine? unless it was a fogger set up your lucky you didnt blow the welds on the whole damn motor.
Art5
white plains, NY
I didn't install the kit. The guy I bought it from did that.It was wet through intake and I used it few times. Later i learned that it was not set up right at all, it was suppose to be direct port kit, but what welds are you talking about?
Because I have 2 kits now, and I'm planning on installing it soon, hopefully.
zach44102
BIG TURBO
Georgia
I was being sarcastic, wet shots on our motor do not work unless its a fogger set up. wet shots puddle in the intake runners and then KABOOM.
Art5
white plains, NY
I know, i found out about KABOOM later and then I Joined this forum and read more explanation about nitrous setups. I have direct port setup and intake ready for it, but for almost a year now, I was thinking about turbo setup, but Now, since I started my new business, I can't spend money on toys yet.
wet direct port is still good, right?
zach44102
BIG TURBO
Georgia
whats the most thats safe to spray dry thru a 3.0 mtx
A dry shot. 55-75 on a stock motor. you can go to a 100 shot with a bigger pump like a walbro 155lph. Zex part number #82011
whiteguy3
Scott MacIntire
Silver Spring, MD
100 shot is fine on the stock fuel system. You do not need an FPR or bigger fuel pump. Copper plugs and some timing removed will do the trick.
