spark plug keying.
sho4life
midwest
Something new I read today. IS it worth the bother on a SHO engine.
sho4life
midwest
If its the same term..something to do with using different crush washers to get the electrode in the proper position for optimal burn.
Lorenr
Vancouver,WA
Indexing your spark plugs
We tried this years ago and it involves screwing in the plugs until the electrode is 180 degrees from the exhaust valve (At least I think it is the exhaust valve and not the intake valve). Anyway, theoretically it is supposed to help power.
Unfortunately it falls under category: Romance BS.
Once spark plugs have the right heat range, multiple electrodes, etc almost never work.
Platinum Plugs (double or single), Iridium plugs, Duel spark plugs and spiral core plug wires do work.
:wave:
AREA 91
Area 91
Most engine builders call this spark plug indexing.
It's not worth it on a street engine.
This does help when getting into high compression race engines.
Ignition systems have come a looong way! The racer's of the 60's could only dream of the ammount of energy available in a modern ignition system.
I have this done on a few drag racing engines.
rbruso
unlikely
Tucson, AZ
I was under the impression indexing was only really useful on 2 valve heads where the plug was way off center in the combustion chamber.
itwonder
VA
It is useful in certain direct injection engines.
firebat45
Edmonton
This. Our spark is right in the center of the chamber, not way off to the side or in a pocket somewhere. I'd be very surprised if it was worth the hassle to do it on the Yamaha. Who knows though, I could be wrong.
I misread the title as "Spark plug keyring"...
