subframe question
SHObogdan1
Michigan
Hi, I have a 1993 Taurus SHO atx and part of the subframe right by the passenger side subframe bushing broke and I need to find a new subframe. Does anyone know what vehicles are compatible? Are all the subframes the same in 1989-1995 Taurus/Sable/SHO? Any help will be greatly appreciated. Thank-you!
Mike Spataro
E.Meadow, NY
I had the same thing happen to me and it looked pretty bad. I took it to a body shop and the guy was really helpful. He resurrected it by welding it back together and did a great job. He was recommended by a muffler shop that does custom work.
Ask around and you should find a shop in your area that repairs older cars or even a spring shop that is used to welding frames, it should be repairable.
I think I spent about a $ 125.- $150.- for the repairs.
Good luck.
SHObogdan1
Michigan
This probably has been answered 100 times but I couldn't find a thread that explains it. What else would I need for the gen 3 subframe upgrade? How would that work with the motor mounts? Would I need different motor mounts?
there is a thread that details this, but the short answer is you need the gen3 subframe, lower control arms, spindles/knuckles and bolts to mount the rack. you use your existing struts and motor mounts, and you need to drill a new hole for the front mount (because its in the wrong place on the gen3 subframe) and space that front mount up 5/8" iirc.
I would do that swap rather than pay $150 for welding on existing subframe, because you should be able to pick up all the needed gen3 parts for around $150 at the junk yard, and when you are done you have better suspension.
LOUDSHO92
Rancho Cucamonga, CA
If you need help finding a Gen2 ATX subframe we have a few available at SHO Source Where can ship you a west coast rust free subframe if you want.
LOUDSHO92
what if he needs Gen 3 swap subframe, what would you say to that?
Then more power to him? Not everyone is capable of doing a Gen3 swap.
I was offering the ability to get his car back on the work with the minimal amount of work. We have shipped a few subframes for this reason.
Art5
white plains, NY
So, why not try to sell him Gen3 swap parts?
SHObogdan1
Michigan
Thanks again for the suggestions guys. As for the Gen 2 ATX subframes, how much would you charge for the part plus shipping? The only reason I am asking is because I am a bit tight on cash right now. If the price is right, I would definitely consider buying it. I already bought spindles from a 94/95 taurus/sable/sho for the 11.6" brake upgrade. The splash shields were rusted and there wasn't much left in them. I probably spent like $70 trying to get new ones from ford. I also already have stock lower control arms to replace so the Gen 3 subframe upgrade seems unlikely for me right now.
Mario, my car is a bit rusty underneath, especially at the subframe. I think that the clunking noise I was telling you about (coming from the front passenger side) is caused by part of the subframe breaking off at that bushing. I tested this out by power braking (putting the car in drive, one foot on the brake and the other on the gas) and the unibody rises up about 3 inches from the subframe right where that bushing is. Let me know how much that rust-free Gen 2 ATX subframe cost guys please. Thanks again.
LOUDSHO92
We don't have the parts to sell.
You wont need those splash shields, just so you know.
Ill send you a PM.
SHObogdan1
Michigan
I already have new splash shields but thank you though, i just have to rivet them onto the spindles.
