Help with codes.
zach44102
BIG TURBO
Georgia
I just pulled my codes after the check engine light being on for a year now and i got a couple codes that im not to sure what they mean.
i got 114- i understand thats normal
519-PSP switch/circuit open
126-MAP or BARO sensor out of range
112-Intake Air Temperature (IAT) sensor is/was low or grounded
im going back out to clear the codes and then try again... thanks
zach44102
BIG TURBO
Georgia
I cleared the codes and did a KOEO and got
not worried abouT the first two
126
114
519-PSP switch/circuit open - PSP
551-Problem in Intake Manifold Runner Control (IMRC) solenoid/circuit - Solenoids
KOER test and a cylinder balance test my codes displayed where
116
114
538
521
note i did turn the wheel when i performed this test but was i supposed to hold the wheel turned?
91PDXmocha
Portland , Oregon
519 is a bad power steering switch
The intake runner control , you should check to make sure your secondarys are working. rev car in nuetral and watch the butterflys .
frosho
WOLFMAN
Tyngsboro, MA
What makes you think the 114 is normal? It's not. Where is your IAT sensor located? Do you still have that hot air intake installed?
The only "normal" code that I can think of is 542, which is triggered every time you stall the car.
zach44102
BIG TURBO
Georgia
i have a stock intake now with a k&n. i think i pulled the codes the wrong way so ill try again in the morning
