Horn help
Phokus
Vroom Vroom
Quincy, Massachusetts
My horns sound pathetic and embarrassing when the car is off, they aren't getting enough juice.
When it's on they work better but still sound weak and crappy.
I have a pair of Stebel air horns, yes pair. 139db x2? I used to have it on my bike before I sold it. I wanted to hook them up but found that the original horns I have are two separate horns high tone and low tone.
They both only have one wire connecting them.
How would I hook up my horn to the switch? I have a separate piece of wiring for these horns to a relay and they will draw power directly from the battery.
The original circuit only serves as the switch. The horn wiring I have needs the two horn wires to connect but these horns only have one.. How should I get this done?
sho4life
midwest
if the hrons are good and fuse is good and they still dont work i need a clock spring? right?
SHOred
North Carolina
clock spring
It is easy to check out a clock spring. Pull the clock spring off. then take an ohm meter and check each wirecoming out of the clock spring on the top and bottom. I found 1 wire that was not making contact thru the clock spring. I had a used one so I checked it out with the ohm meter and it was good. Reinstalled the spare I had. Fixed my cruise control and stopped my constantly flashing air bag light. Took about 3 hours to ter it down and check it and put it back together. Good 3 hours spent.
SHOred
