How to remove mtx bearings
deercrusher
never running!
PA
Do you mean the main bearings between the main caps and the crankshaft?
Step 1 Drink a case of your favorite beer.
Step 2 Stop kicking puppies or whatever you did to deserve this
Step 3 Remove motor and put on an engine stand.
Step 4 Remove Oil Pan.
Step 5 Remove engine damper pulley - crank sprocket etc... blah blah blah
Step 6 Remove crank bearing caps.
Step 7 Remove crank - and bearings off of crank
Step 8 Remove other half of bearings in block
I know I left out the part about removing the trans and the rear main seal and all that - just wanted to give the beef of the info here. - It is better to remove the motor and put it on a stand rather than try it in the car. Good luck to you.
Racer X
SHO Pilot, Retired
Connecticut
He means the bearings that are pressed onto the mainshaft inside the MTX-IV.
The answer to which I don't know, sorry.
AREA 91
Area 91
How do you remove the bearings on the mainshaft?
If you are talking about the MTX4 main shaft bearings, you need a bearing puller and press.
I have 2 questions for you:
#1 Why are you replacing the bearings?
#2 Have you found replacement bearings?
Phoenix
SHOHOLIC
QC , Canada
According to Josh , the only one that you cant have is the pressed one on the output shaft. Lucky me , thats the one that failed in my spare tranny. You can buy the cup , but not the actual bearing.
