here my list off code that suck
moobypets
mooby
quebec
here his my code list 18 96 87 67 59 49
and car was running like shit jumping from 1000 to 700 and then back to 1000 and then a jump to 1400 and it was like it was miss firing
plus i have the code 13 high idle suspect bad iac lol and it all started at the same time
18 = SPOUT circuit open
96 = high speed fuel pump relay open
87 = fuel pump primary circuit failure
67 = a/c on during test
59 = low speed fuel pump open
49 = SPOUT circuit open
SPOUT issues are either the jumper is missing or the wiring has a problem. the wiring for SPOUT is along the rear of the engine, and can get toasted by the rear exhaust manifold if not properly tied up. the engine will run fine but be WAY down on power with this situation.
Fuel pump issues are either the pump, the ccrm or the wiring, in my experience. the engine will not run right with those issues, so you will need to trouble shoot that and solve it. unfortunately, we cannot help much with that - you will need to ohm out the various wires, etc. to see where the problem lies.
moobypets
mooby
quebec
just remember i normally crank my engine with the dis unplugged to raise oil presssure so im sure most off them are from that
the only real code i have is 13high idle
