Tokico Eibach vs Koni Intrax
Toul
Columbia, SC
93 mtx, 29mm rear sway bar, subframe connectors.
Ive got the Tokicos and Eibachs on there now. I wish it was stiffer. (thats what she said)
Can someone please tell me what I'm going to think about switching to Koni's and Intrax?
zblackbeast
SHOtarded
Omaha, NE
I know the spring rates of the Intrax are much stiffer, as well as the koni's being adjustable from 5-55% stiffer than stock..
Also, if you happen to be in the market, i have a NIB set of both koni's and intrax for sale!
EDIT: This also works as a POR!
http://www.shophoenixproject.com/pages/susp.htm
about 2/3 of the way down!
Toul
Columbia, SC
I THINK shoshop was who made them? I may be wrong though. All I know is that its thick as ****, and red. Was on my SHO when I bought it from Cobria.
.RaMpAgE.
Las Vegas, NV
koni/intrax is stiff what i have on my car it can be a lil harsh for daily driving but i have it set to full stiff pogo ever so slightly on a series of bumps
zblackbeast
SHOtarded
Omaha, NE
I was really looking forward to getting them installed on my car.. I just haven't had time.. Like i've said, I've ridden in a SHO with this setup and I really enjoyed it!!
yamahaSHO
E85 whore
Arkansas
The Intrax are marginally stiffer than Eibach. In fact, they start out softer in the progressive coils.
Intrax 30.1.026
Front; 143-266 lbs/in (25.0-46.6 N/mm
Rear; 123-249 lbs/in (21.5-43.6 N/mm)
Eibach 3528.140
Front; 151-257 lbs/in (26.4-45.0 N/mm)
Rear; 149-194 lbs/in (26.0-34.0 N/mm)
boat
Likes blue ones
Tallahassee, FL
hmmm...nice. I didn't realize Intrax and Eibach were that close as far as spring rates. Thanks for sharing the info. ;)
Intrax 30.1.026
Eibach 3528.140
kevinspann
Don't take my advice.
Richmond VA
The fronts seem close, but the rears are where the intrax look to be stiffer, based on that. But, it's also a matter of where the rate changes in the compression of the spring. Do the Intrax get stiffer before or after the Eibachs?
.RaMpAgE.
Las Vegas, NV
didnt realize they were so close but yea i felt the rear end get alot stiffer when i installed them plan on cutting 1.5 coils in the front the drop the nose make it a lil stiffer
SHODWN
Mother Threasa
Spencer,Ma usa
Save your money..
.RaMpAgE.
Las Vegas, NV
i would wait and save for the coilover suspension either i think the selex or w/e that new one is their coming out with i mean its 2k but its only a couple hundred buxs more after buying mounts and the work thats required for the konis plus the spring compressor
