Monroe quick strut question
Mossdahaus
Royal Oak, MI
Just got my 95 MTX and the PO put new Monroe Quick Struts on the front. The back struts are fine but the springs are sagging with only 73k on it. I was wondering if I go with a full set of Moog CC springs, is there anything stopping me from swapping the Moogs onto the Quick Struts?
thegovernor9912
NJ
hahaha I am guesssing you didn't replace them yourself the first time?
pinch bolts can lead to hours of cursing
K-Dawg
Treasure Coast, FL
Ignore warmonger and thegovernor9912.
You'll have to remove the strut assembly, compress the spring, and remove the nut from the top of the strut. Replace the old springs with new, and reassemble and reinstall.
oneqwicksho
cleveland, ohio
What he said. But I would recommend the soaking of the pinch bolts and some heat. When I did the suspension upgrade on my car I was calling it every name but an sho cause the pinch bolt snapped off 3/4 way out. Man I was ******
Mossdahaus
Royal Oak, MI
Thanks for the heads up! No I did not do the front suspension myself as they were JUST done by the previous owner. I literally just bought the car Saturday and am getting ready to dump some money into it to get it to where I'm happy with it (it'll take quite some time AND money to get there) but luckily it only has 73k on it!
zach44102
BIG TURBO
Georgia
i have never had a problem with pinch bolts... well....... i also have a impact wrech but you definitly need to replace strut mounts.... my sho is getting new rear strut mounts tomorow because they go BONG!!!.BING!!!BANG BANG BANG BANG
K-Dawg
Treasure Coast, FL
Quickstruts come with springs and mounts on them. If they were just put on, I doubt the springs are sagging.
warmonger
earth
you guys also do not live in michigan like the op...they arent going to come right out for him if it was driven in the winters
I have found the secret to successfully getting the pinch bolts out is to back them out as far as they want to go, then back in until nearly tight, then back out as far as they want to go. in this way, a lot of the rust that has accumulated can find its way out, so that after several back and forth operations they will eventually come out. I haven't broken one yet.... And, liberal applications of PB Blaster will make this all possible.
Mossdahaus
Royal Oak, MI
If you read the initial post it says the quickstruts are on the FRONT and the REARS are sagging. I am wanting to replace all 4 springs with Moog CCs so I can lower it just a bit. I do not want to purchase new struts for the fronts if I do not have to seeing as they are new. I will purchase new ones for the rear since I will be swapping the springs out. Thank you for all of the advice on the pinch bolts...never would've guessed! :munch:
Are the quick struts essentially sensa-tracs?
K-Dawg
Treasure Coast, FL
Your post is misleading because you talk about new Quickstruts and putting new springs on them.
Now that I know what you're asking, yes Quickstruts use SensaTracs. Nothing wrong with Moog springs on the Quickstruts, or on new rear SensaTracs. The pinch bolts can be a pain, but take your time and you won't have any issues.
Mossdahaus
Royal Oak, MI
Sorry for sounding sounding so misleading! :bonk:
Well my KTM supermoto is about to sell on ebay and I just sold the probe so now its time to start having some fun getting the SHO to where I want it! (quick/ spirited daily driver)
