Factory alarm!
2dopekilla
95 ATX
Iowa/DSM
So i just got a 95 atx real clean car with only 87k on it anyway the guy told me the alarm worked you just needed new batteries in the remotes i got new batteries and nothing happen. i have a keyless pad that i got the code off of that little box in the drunk on the driver side so that works but while serching in the manual and poking around the car to figure why the alarm wont work i noticed a wire that looked like a anttena wire unpluged from that box so i plugged it in nothing happened but would like to no how i could reset the alarm or just get it working and what that wire dose
naval-avi8or
Chesapeake, VA
You maybe confusing the keyless entry with alarm. Alarms were offered only as a dealer add-on. Is the box you are refering to located in the trunk next to the jbl audio system. If so that is the remote/keyless entry module. There is a connctor located behind the trunk lining on the drivers side that can be shorted using a paper clip along with the correct sequence to reprogam your keyless remotes. I haven't done in years but I'm sure some one will chime in here and point you in the correct direction.
As far as the alarm I've got one and it's still in the box as I modded my car and it is no longer compatible/needed due to the PATS system.
RickieFrat
La Cosa Nostra
State of Corruption - RI
Is there a Ford logo on the remote? If not, then you have a aftermarket alarm that should be located under the dash and the remote would have to be re-programed for the alarm unit.
If you do have the Ford logo on the remote - replace the batteries and then follow the steps in programming the remote for your car. I believe you have to jump 1 of the plugs in the trunk and turn the ingition key to on. If you seach for it (thread topic) - you will find it.
