the47guy
option 1
Option 1 is more than adequate. Look at almost every single oem turbocharged vehicle, they don't run a sealed turbo, they run an oil feed off of the motor.
I wouldn't even trust a sealed unit. Turbos can get to 1500F and glow red hot, what oil can handle being encased in that? At least when the oil is flowing through the turbo it doesn't have time to heat up to the turbo's temperature completely.
Any other info on the kit mike? IWG? What size DP and does it mount up to the stock catback? Anything need to be remounted out of the way? (radiator hose, ABS comp, ICRM?). A WB02 is always a good thing, and having the bung installed in the DP, ready to go, would be great. Lastly, what are you going to be using to meter the air, and where will it be placed? Vent to atmosphere BOV or recirc?
My guess is that they are not considering a twin scroll setup as it would require equal length headers all the way to the turbo. Depending on the placement of the turbo (with the SHO being difficult), that would be very hard. I'd imagine that would increase the price exponentially.are these air foil bearings or twin scroll turbo being considered? What is the time frame of a kit being offered?
I prefer option 1 with the above features :thankyou:
http://www.grc.nasa.gov/WWW/StructuresMaterials/TribMech/research.html
"High-speed rotating equipment operating without oil lubricated rotor supports . . . bearings, dampers, seals" Find out more about recent technology breakthroughs in Foil Bearings, Tribological Coatings, & Analytical Modeling to enable High-Speed & High-Temperature Oil-Free Turbomachinery.
Team Lead: Dr. Christopher DellaCorte
Technology Overview
Analytical Modeling
Foil Bearings
