Idler Pulley on 3.2?
swami
No. VA
hi all,
the bearings are getting noisy on my serpentine belt assembly and no one has one available including rockauto and the stealership. it is ford part# E9DZ6B217B. i haven't looked on fleabay yet. any suggestions aside from pressing in new bearings? TIA
swami
No. VA
yeah the stealership told me there was a 4-rib and a 6-rib! WTH i have a 6-rib; do you know the bearing number before i press my old one out? we having a bearing and transmission parts suppier in my town. TIA
Phoenix
SHOHOLIC
QC , Canada
That bearing is not listed in bearing shops , been there done that.
Only way to grab these is through SHONUT or SHOSOURCE.
Or a used one.
The 4-rib and 6-rib is for the mtx cars. The atx cars obviously only have one 6-rib belt.
swami
No. VA
thanks for the info. why didn't ford put the 6-rib on all of them and be done with it! com'on?
SHOtimer
#2910
Santa Clarita, Ca
PM sent.
I've tried to sell the ATX bearings on here before, I have a stock pile of NOS pulleys (both upper and lower)...
Doug
93MTXSHO_STUD
lubbock, TX
a temp. fix would be to use a pick tool to remove the bearing seal and pack some grease in the bearing. I've done this many times with good results. I long time ago I had NSK stop their production line in Canada to make me some OEM bearings with the correct part numbers...don't know if they would still be willing to do that.
swami
No. VA
well i finally got my new idler and belt installed and the bad news is that it only partially fixed my noise problem because my power steering pump is getting noisy. i guess i can live with it until i do the 100,000 maintenance.
for those interested the bearing part# is NSK BD20-15DWA and is available from bearing distributors for $38.50. HTH
swami
No. VA
NSK BD20-15DWA is for the top idler and tensioner. 35BG05S10G-2DS is for bottom ATX only. shonutperformance has them for $78.08 (ouch!) in their 60k section. HTH
SHOtimer
#2910
Santa Clarita, Ca
I'm glad you got that new pulley/setup and it worked out for you.
I have my ATX torn down right now...the p/s pump is easy to get to when you are doing the timing belt and have the front of the motor and intake off fyi...
Doug
Edward Birdsall
Brewster, NY
Hey Shotimer, do you still have any NOS lower idler pulleys in that stock pile of yours from back in 2010? I'm looking to buy. I have a 94 SHO ATX w/AC. Thanks, Edward
