boat
Likes blue ones
$1200. I am figuring that to get that off to a front 60k, its going to take some heat. Not a big deal tho, I have a new SHO Source UDP to put on there, so if the current pulley gets trashed, not a big deal.
Other than the hack job of the engine swap, the car is really clean otherwise. New suspension, fuel pump, exhaust, tires.
We got it torqued to 150ft/lbs. Its all good... Thanks tho, thanks for letting us use that bar.
The crank pulley face does sit higher than the crank face, so that's not a problem. Also, although there does seem like there's slop between the crank pulley ID and the crank OD, IMO it's an optical illusion created by the red loctite. There's chamfer on the end of the crank, that's what the space is. If you had that much clearance between the crank pulley and crank, it would have f'd up the woodruff key and crank pulley by now. Looks to me like the PO got confused on where to put the red loctite.
Too bad it's such a hack job, how much did you pay for this car?
With the hood on, and that bar, you kinda gotta "click it" by hand to be able to use it like that.. Probally shoulda told u that... hold the bar up, and see if you can turn the socket end by hand a little..![]()
Or pop that hood off real quick... not hard to do at all....
