Light Bar
shoon
cliTaurus
Dawson Creek, BC
It is well known stock headlights suck... and even after getting some aftermarket fogs installed in the stock locations, I am still not happy with the amount of light.
I live way up north, and in the fast approaching winter months we only get 7-8 hours of light per day.
So, do aftermarket light bars exist for these cars? or has anyone fabricated one, or have any good ideas for a light bar that might look good?
whiteman_01
Well-Known Member
Hastings, MN
Your best option would be to look into an aftermarket headlight harness, and a good pair of high wattage bulbs. You can run an 80w low and 110w high beam with no problems.
Im not sure on the quality of this harness, i think there was one offered by piaa (someone correct me if im wrong) but you can use this as an example.
http://cgi.ebay.com/ebaymotors/9007...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
EDIT:
I found the harness that a lot of members here use. It is from suvlights.com, and is actually cheaper now than it was in the past.
http://www.suvlights.com/product_info.php?products_id=112&osCsid=b38df040bbdd4adefee65e74f874e7e9
K-Dawg
Treasure Coast, FL
Is your car a Gen 1 or 2?
After new housings, good bulbs (Sylvania Xtravisions, in my case), suvlights.com harness, and some decent driving (not fog) lights, I've got about as much light as I can use.
Oh, and aim it all correctly.
Phoenix
SHOHOLIC
QC , Canada
Clear New housings from rockauto and some silverstars bulbs and you are golden. Bright and clear.
Cocoa,Florida
ive got the same setup except im running silverstars i think.
plenty of light after i did the sanding treatment to the housings and did the harness upgrade.
