ATX trans pan
cobrakidd03
michigan
I changed my ATX pan gasket and there are 3 bolts that are stripped. How can I fix them or get new ones??
hawkeye18
Sorta cares
Norfolk, VA
If it's the bolts, get new bolts. If it's the bolt holes, get an appropriate tap and tap new holes in.
Edit: Take one of the old bolts to AAP for size identification, but I'd be willing to be they're M8x1.25x20mm.
SHOtimer
#2910
Santa Clarita, Ca
I think you will have to pull the pan again and properly repair the threads in the tranny.
I learned many years ago - that those aluminum transmissions are very soft and not to torque those bolts too hard....
Doug
cobrakidd03
michigan
Ya I guess I found that out also. Now what do I need to get in order to repair them? This is first so I am clueless
byersmith
SHOpwrdMR2?
Toledo,Ohio
A metric tap and die set and replacement bolts if you chewed any up trying to cross thread them in the case. torque for the bolts is probably around 10-12 ft/lbs dont quote me on that tho.
Byersmith
cobrakidd03
michigan
where can i get a metric tap set at? do they have specific one for diffrent bolt sizes?
byersmith
SHOpwrdMR2?
Toledo,Ohio
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=39384
And you can use that fancy tap set you just bought to fix your bad bolts. Just take a good bolt from the pan and try to match it to the appropriate tap. It should thread correctly (tight with no wobble and no force needed). Now use the tool inside with your tap and pop those suckers in a vise and re-tap. As for the pan just make sure you are using the correct thread pitch as you already should have identified with a good bolt, get the tap in the bad hole(s) and make sure its straight on with the hole and turn it (but not to far and do not force) as you may crack the case.
Byersmith
Use a 1/4-28 bolt. It is just slightly larger so you don't even need to tap it. I used SS bolts and just let them cut the threads.
It works. Otherwise you are going to have to put helicoils in it.
The 1/4-28 bolt is a fine threaded size. Mcmaster.com has them in stainless steel. Grade 8 would work too.
