secondaries question
walser
new ulm MN
alright, this maybe a dumb question but when are the secondaries supposed to open up? ive talked to a couple guysabout this and they tell me around 3 grand, but some say 4, and on my car its 4 grand. does this change on some years? i have an autologic chip that changes it too about 3800 rpms, and about every gear i go up it goes up around a hundred rpm. until i hit 5th and its arnound 4300 rpms when they open up. so im not sure if this normal or not... oh and the cars has ported runners and bored butterfly vales and tanks. not sure if that would make a difference...?
thanks all
:thankyou:
firebat45
Edmonton
There shouldn't be a difference between the gears, the EEC has no idea what gear you're in (nor does it care). I believe stock is 3950, so essentially 4000.
so when your engine is under ever increasing loads (rowing through the gears), you feel the secondaries open up later and later?
You have a vacuum leak or something
Run through first...slowly and listen for the secondaries. If they open later than 4000, that confirms vacuum leak, IMO.
CademiaX
What's an SHO?
Utah
When my clutch started to wear they didn't kick in till about 4200RPM, with a nice new stage 2 clutch they usually kick in about 3800RPM.
I don't have any chips or anything either. and why chip it? don't you know how to dump the software and decrypt it? whats wrong with you?! ;)
That's been my experience anyways.
I have no idea why that happened.
operdot
USA
DO you guys really open the secondaries that often to care if they are within a 300 rpm range?:3gears:
Personally I haven't opened up mine since a couple gas tanks ago.
SuperHO
Mental Patient
St. Joe, MI
you're bein naughty...the secondaries don't open in 5th till around 93mph...and that's 4k.
AREA 91
Area 91
Stock opening RPM is 3950
You can change the opening rpm with a tuning device.
walser
new ulm MN
yes every gear i go up it seems to open a little later, and this is a completey new intake plenum runners tanks and bbs than my old stock one and it did that with my stock intake too, and i have a new clutch in it about 4k old its only a oem but i dont drive that bad ;) and the chip i have does make a difference but it makes it idle horrible and sounds like it has a massive cam, even though it does sound pretty awesome, haha. the chip is used, but i got it from the same guy i got all my parts from, i got everything off that car except the 9lb flywheel and stage 2 clutch, and an 80mm maf. that may be the big key as to why, but doesnt solve the secondaries question
Racer X
SHO Pilot, Retired
Connecticut
What, are you kidding? Do you have any idea how many people on here have 4kFTW for their license plate? :)
SuperHO
Mental Patient
St. Joe, MI
my bad...my secondaries open at around 110 in 5th...found that out this morning as i was running a bit late for work.
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Thats what Im talking about! When I had my SHO, they were opened up every morning on the way to work. Some people need coffee...some mountain dew...some, just secondaries to wake up.
walser
new ulm MN
haha i have to resist to not open my secondaries every time i drive it! and about the secondaries being open all the time is that bad or cause any harm? and does it have any low end torque? and everytime i start it up it revs to about 2 grand then it will go down to about 500rpm, and if i give it one pump itll rev up to about 12-1300 and slowly go down and idle good at 850-900. this happens without the chip and only when i start it after its been sitting for a couple hours. i can start it and start it after and itll purr like its suppoesed to... anyone have any ideas?? any help is greatly appreciated, my dad was thinking something with a vaccuum leak? :salute:
zblackbeast
SHOtarded
Omaha, NE
I think on my way to school today (about 15 miles, i had them open about 7 or 8 different times.... :) I try to be nice to it and max my MPG.. but with the intake i have on it, they are just obnixously loud..... and its ok.. Its my crack.
expy916
sacramento
Found your problem, remove chip. NOW!
walser
new ulm MN
the chip is out and being retuned by SHO source as we speak. and the car still does it when the chip is out, considerably better than when its in but still is not right, it should not be doing that :p hah if i could figure it out
