1995mtxsho
Are there any other cars that use the same spec AX4N as the SHO?
the 4.6 conti looks identical but is the bellhousing the same??
Which AX4N is that?So an AX4N that bolts up and is rated to handle significantly more HP and Torque, wouldn't work as a viable replacement?
I thought the 90s windstars had the AX4N trans in em?
The premise of your question is flawed. Just because the Conti AX4N was bolted to a 4.6 doesn't mean it was "upgraded" in any way. You're making an assumption that unfortunately doesn't hold any validity.Umm the 4.6 liter Lincoln continental AX4N.
It's certainly a more powerful engine, therefor should be just as stout as the SHO's.
Hence the original question of the bellhousing, and then the comment about the input shaft splines.
I do, however, believe there has to be a difference between the regular 2.5/3.0 AX4N and the one in the 4.6 continental to make it hold up to the increase in power like the SHO.
The SHO AX4N doesn't have a VSS and can't use one. A snout-mouted VSS will hit the rack, and a barrel-mounted VSS will hit the exhaust manifold. That's why the SHO gets its speed data from the ABS system.Ok, point taken.
The next logical question would be; what is different in the SHO transmission that sets it apart? Aside from the obvious torque converter and vss placement.
Again this is just intended as a discussion for finding facts, as it is difficult to find solid information about differences and specs.
Logic has little to do with Ford FWD transmissions.
