Name this gasket
38SHO
#1 Oil Abuser
North Palm Beach
if thats truly a taurus transmission side cover gasket
make sure to give it its proper name either being from the
AXOD, AXODE, AX4S or AX4N transmission
when u start talking about ATX stuff, 99.9% of the world out there besides SHOForum thinks of a different 3 speed 80's transmission Ford made, that is actually called the ATX.... I wish people would get passed this habbit, and use correct terminology so you don't sound like a fool to other people-or confuse them, but old habbits die hard....
HotRodKid
mmmmm ... turbo
Western NY
drop DS suspension & pull cv shaft out
disconnect a bunch of wiring
drop subframe & support
support tranny, remove tranny mount
replace seal
reassemble
Racer X
SHO Pilot, Retired
Connecticut
I've heard that all you have to remove is the drivers side halfshaft and fender liner, support from underneath, remove the transmission mount and mounting boss (it's removable), and bingo, off comes the side pan.
I've heard, anyway.
Roady94
CT, USA
. . . . I wish people would get passed this habbit, and use correct terminology so you don't sound like a fool . . . .
- I guess we all have our pet peeves. I wish people would get past the habit of using incorrect spelling, so they don't look like a fool when they criticize others for using incorrect terminology.
cobrakidd03
michigan
Dude no need for the BS. All I asked was a simple question, if you can't help then you should not bother to clutter up the boards with useless crap.
Racer X
SHO Pilot, Retired
Connecticut
Well then it's a good thing we're on SHOForum, where 99.9% of the people who read ATX knew he was referring to the AXOD-E (AX4S for 1994 and later applications).
:shakehead
cobrakidd03
michigan
Well thanks for the "some what help" if any one cares I did locate one at our local Murray's. Had to order it and it was 7.00
yamahaSHO
E85 whore
Arkansas
I don't have an ATX SHO and I knew what that was :) Then again, I know what every gasket on the MTX cars look like.
NovaSS
Project MINIGUN
I would name it "Bob", its just looks like a "Bob".... or maybe "Mark", ya... thats what I would name it, "Mark The Gasket"
hawkeye18
Sorta cares
Norfolk, VA
make sure to give it its proper name either being from the AXOD, AXODE, AX4S or AX4N transmission
Also, while we're being *****: the AXODE and AX4S are different names for the same transmission. The AX4S (AXODE) and AXOD all use the same gaskets. The AX4N uses the same side pan gasket as all the others IIRC.
Also, +1 on making sure your shit doesn't stink while holding your nose at others' shit. Doofus. It was a SHO guy asking 10,000 other SHO guys about a SHO question. If you really want to be 'the rest of them", I suggest you go to a Honda forum where they neither know nor care what you drive or anything about it.
