Project 275
SHOspazz92
Banned
Triad Area, North Carolina.
How light is your SHO? Mine is still fairly heavy and i already cut up the fenders and have the tires. I will see how it is at my next track event if i run into problems i change it over the winter.
IIRC Correctly, Eric has his Battery in the back as well as the tank for his Fire suppression system. I don't recall if that car has a Fuel cell back there as well.
-Sam
Shoaz
Studly dood
Scottsdale, AZ
-Sam
It did have a fuel cell against the rear bumper, but it died (i.e., aged out and started leaking) so I replaced it with a stock tank. There's ballast in the trunk now.
My minimum competition weight is 3374 lbs, so I'm not especially light, either.
92sho16
b00sted
Liverpool, NY
Wouldn't heating up 275 r compounds be like heating up a smaller street tire? I would think that if i couldn't get the tires that warm they would still be stickier than street tires. Other thing i was thinking of was that the glen can be a fast track and avg speed around the track can be pretty high by comparison maybe that will be in my favor.(i really only have been doing events at the glen)
drivinhard
Gainesville, GA
R comps, until they have any kind of heat, are slicker than snot on a door ****. Even the A6, which is designed to have stick real quick (for auto-x application) can be pretty slippery till you really get SOME heat in 'em.
yes, for a high speed track like the glen, you should be pretty good. high speed will put heat in a tire as good as anything. just work your way into it, a couple of laps @ 7/10ths. you can always run lower pressures in the rear to help as well. hoosier's tire pressures specs are pretty high IMHO, so take their recommended specs (hot/cold) and subtract about 3-7 degree, depending. guys racing/winning on the A6/R6, aren't running a lot of pressure in them. lower pressure will shorten the useful life a little though.
92sho16
b00sted
Liverpool, NY
I didnt think there was much to update because i have touch the fenders since august but i guess i never posted pics of the progress. Pics
