Steering wheel wobble problem
SHOOFF13
SHOOFF
Massachusetts
While driving my sho the steering wheel shakes uncontrollably from side to side. I mean I am able to drive the car, but obviously have stopped before I damage anything else. There is a long story to this whole situation, but I really don't want to get into it because it ****** me off. I was wondering if anybody has any answer to what this problem could be. I was thinking possibly a tie rod or the axle? Any help would be awesome because I am looking to get it fixed asap and restore it once again. Ahh these damn SHOs are addictive.
Brett
SHOs before HOs
Minnesnowta
I was guess a dangerously worn tie rod
Devin
3.Slow
Pacific Northwest
Check the wheel bearings too. If they go there can be disasterous results (from what I hear...)
ultimatesho
Fort Bragg, NC
best advice jack the car up and try to wiggle the tire back and forth.....if theres play u should c were from......my best guess would b eather a tie rod end or wheel bearing
I get the same symptoms if the front brake rotors are warped, which is a common occurrence, especially if the tire guy isn't careful to torque the wheels properly.
SHOOFF13
SHOOFF
Massachusetts
Thanks for all the suggestions guys. I'm going to jack the front end up tomorrow and see if any part has any play. I will let you know what the problem ends up being.
Kens1992mtxSHO
The Commonwealth
My bet is front rotors/tie rod as best case scenario. Worst case is wheel bearings
