Removing intake
cobrakidd03
michigan
I just removed the intake on the SHO for a good cleaning. While I have it off what should I look for as far as matience goes? Do you think I should clean the inside of the intake? I tried to pull one of the plug caps off and not sure if the whole thing pulls out or not so i stopped. any tips and ideas would be great.
:thankyou:
SHObill
'The Collector'
Rochester MI-48307Detroit
I would think the only reason you would remove the intake was to clean the inside! But best to have a new set of intake gaskets handy for re-assembly thou!
cobrakidd03
michigan
Um ya thats why i took it off!! But i figured while i had it off is there any other items i should be doing? what do you use to clean the inside if the intake?
