UDP belt length.
jon93
Philadelphia Region
There are many different sets. You need to be more specific on the pulley(s).
SHO_DOODmorrris
Owner & Fanatic
Alberta
is hte PS belt undersized too? thanks im just on my way to napa to grab these as soon as i knonw you guys are awsome TIA
LJRuddy
Pop lock n drop
Poaceae fields
If they are the same as SHO SHOP's UDP's, you need this:
Gates K060455 6 rib alt/ac
Gates K040510 4 rib ps/wp
Anyone know if the SHO SHOP pulleys are the same as Shosource?
SHObill
'The Collector'
Rochester MI-48307Detroit
Take old stock belts, cut them & wrap each on its correct set of pullies, then measure the gap if you have the old 3 piece style, OR the overlap if you have just the smaller Crank UDP. Measure the total length of the old one you cut & either ad or subtract.
SHObill
'The Collector'
I thought a belt came with the UDP or was an option. They should be able to tell you if you want to take someones word for it. Just figure it out yourself! not difficult.
SHO_DOODmorrris
Owner & Fanatic
Alberta
Heh... i know that, i was just going to my buddys house to do it and on the way i was stopping at napa to get the parts. he did order it with the belts but they sent him the wrong ones and he just hasent sent them back yet. i just thought somone would know offhand so i could have grabbed a set while i was there, no biggie.
jayro
Auburn, In
The info might be on the website. You could always ask for the same belt as stock but get one that is an inch shorter, and 2 inches shorter. Just take back the one that doesn't fit.
Jeremy
LOUDSHO92
Rancho Cucamonga, CA
Believe it or not we do answer emails.
Mike has the correct belt lengths and I let him know about this.
We had selected the wrong belts but we do have the correct belts now and we were exchanging them.
SHO_DOODmorrris
Owner & Fanatic
Alberta
Whos Mike? He knows you are exchanging them but he just hasent mailed them back. His name is Lindsay
If you could supply what year/make/model i need for each belt that would be greatly appreciated! thanks
-Mitch
LOUDSHO92
-Mitch
Mike, from SHO Source. He has the info.
SHO_DOODmorrris
Owner & Fanatic
Alberta
awsome thanks a tonne bud. now if napa dosent carry the gatoprback brand here is it the same part number sorta for other brands? if not what cars are the belts off? thanks
-M
shopartsnw
SHO Medic
Battle Ground, WA
Pretty universal part numbers.
I really only recommend Gatorback. They are worth the extra money and time in my opinion.
Mike
