Tire Question
Scott 99 SHO
Haverhill, Mass
Hi
I would like to upgrade my tires to 17inch on my 99 SHO:woo-hoo:. What size tire will fit with out any modifications. Also what exact size 17inch rim would be a good choice.
Thank you in advance for your help.
Scott
hawkeye18
Sorta cares
Norfolk, VA
the lug size is 5x108 or 5x4.25. 5 being the number of studs, obviously, and 108(mm)/4.25(in) is the distance between two lugs. Beyond that, a lot of rims will work. Like Steve above, I'd recommend a 17x8(in) wheel with a 235(mm)wide tire. If you google "tire size calculator" and go to the very first result (or hit the "I'm feeling lucky"), you'll get the Miata tire size calculator, which will work for any car. Plug in the OEM tire size (I don't know what it is for gen3s) on the left and figure out which tire size gets you closest to OEM size, assuming 17" wheel size and 235 tire width. You can go to 225 or 245 if you want, but they'll both look funny.
Scott 99 SHO
Haverhill, Mass
Hi,
I am gathering from this information I can use a 235/45/17 with out any issues or should I use the 235/50/17.
Thank you all for your input
Scott
stephen newberg
Ladysmith, BC, Canada
You can use either without problems. However, for most makes and models of 235 width, you will get a closer speedo result with the 235/50, IIRC. What you need to check on this is circumference. Check first for the number for a 225/55/16, the OEM size, and then check with what you intend to replace it with and try keeping it as close as possible to the original value, so as to keep the speedometer as close to correct as it can be. Assuming you care about that, of course. :)
pax, smn
