need some input on possibly getting a 91 SHO
fst100
lancaster, pa
well theres a 91 ford sho 5-speed for sale locally w/66K miles for $1,200
the seller's the dad whos selling it in place of his son-in-law whos in the navy now.
he said it wasn driven much since last winter, but the only thing recently changed that was to be noted was the clutch was replaced, but he said the shop that did it didnt do a good job and its leaking tranny fluid a bit, he said prolly at the axles.
how much is that to get re-repaired? he said the car has no rust spots underneath since it originally came from down south so it has not seen alot of road salt. he also said the clear coats going but i dont care much on that. the seller said there was no need to do any maintenance since the car only has 66K miles on it(ie-intake manifold gaskets, headgasket, etc).
just need some input as well as advice and pointers b4 i make the trip down and taking a look as well as test driving it if its worth the travel. im going to use it as a DD.
kikkinasphalt
Wrrrrrrrr
Missouri
its due for its 60k maintenance
but for the cost/miles id buy it yesterday.
if its axle seals it should < 100 bux to fix.
fst100
lancaster, pa
yea im in the process of reading up on the maintenance schedule but wasnt entirely certain on what he was talking about b/t the clutch repalcement and the leak and where the leak was actually coming from.
edit-i am certian he said he believes the leak is coming from the axles. how har dis it to check and/or replace?
HoustinoJillian
name's JUSTIN
usa
edit-= my carfax expired
fst100
lancaster, pa
well, i havent looked at the car yet, but i may pass this deal. im moreso looking for a DD gas-saver and not looking to spend alot on maintaining above what another vehicle i wouldnt need to. if anyones interested in it just pm and i can giv eu the number. the seller is located in columbia, pa but the car's over in quarryville, pa.
If I were you I would verify the milage with the carfax offer you just got. If it checks out as 66k, the maintenance will be almost nill.
I think you will find out that it's actually 166K. If not...snag that puppy up!
shobote
Naperville, IL
WIth 66k you'll definitely need to do t-belt, water pump, CPS, valve adust, spark plugs, valve and plug gaskets, wires, fuel filter, etc. IF you do buy it, go to the PA SHO guys to get all the maintenence done by someone who knows these cars.
With such low mileage and no rust, that is a very good buy. They probably put a stock clutch in it which is good for a DD, but don't get on it or it will go bye bye. You will also expect around 30 mpg hwy with after the 60k is done.
fst100
lancaster, pa
if i get it the only parts i may be uncertain about is the timing belt, location and access of waterpump, cps and the valve adjustment.
bottonic
Sho ******
East Troy, WI
What color is the car? It wouldn't matter to me if it had 66k or 166k, it would just be that much better opf a deal if it was only 66k! I would definitely snap it up for $1200. The cv shafts are not a big deal, and like everyone says, just plan on doing a 60k.
1995SHO9
FLEES ARE COMIN
Carlisle PA
Your about 45 minutes from me. If you need help checking out a car or somthing, give throw me a pm.
~Johnathon~
