stage 4 clutchs
94SHOgun
Massachusetts
pondering the thought about a borg warner stage 4 clutch for my SHO. any pros and cons on borg warner??
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I think that clutch was listed in a craigslist ad. I highly doubt that it's anything but a stock replacement. That, and I'm pretty sure that the Borg Warner boxed kits were 9 1/4", but don't quote me on it. I've never seen one that was listed as the revised size.
DaSho97
Former Owner
Mass
Ive never even heard of a stage 4 clutch. Whats the difference with it compared to a stage 3?
animex2
T9 Technician
Buffalo
ShoSource sells a stage 4 southbend clutch i was looking at.
btw... im a bit informed / noobish here, whats a clutch kit and how do you use it? Do you have to take apart the stock clutch, and put those new parts in?
sorry for the hijack, im looking for the same info as you =)
LOUDSHO92
Rancho Cucamonga, CA
For a clutch kit it just has all of the parts to directly replace your clutch with a new unit.
Unless you have a turbo or s/c you dont need stage 4.
animex2
T9 Technician
Buffalo
i got the parts list and installer all set up for a turbo, getting a little GT-30 to throw in ;)
94SHOgun
Massachusetts
yeah it is not a stage four clutch. was a craigslist add. was for a heavy duty borg warner. is measuerd to 9.75" not 9.25. i brought the tape before i bought the kit. got for 150.00 second hand brand new is better then paying 275++ any were else. he had the revised ceramic throw out as well. down fall is there was no clutch alignment tool though.........
dodgebusta
Online/Offline
Hudson, WI
Alignment tool isn't needed just makes it easier. If you have something to put through the hole that is approx the same size as the trans input shaft thats all you need when tightening the fly wheel. HINT drop the whole subframe, I helped joe with his gf's car and we ended up using a scissor jack to help lower the drivers side of the subframe.
Somebody I saw had really good pics of doing the job too.
LOUDSHO92
The only bearings that are ceramic are the SHONut bearings. Just because it is revised doesn't make it ceramic.
You got a stock clutch.
