Uh oh! help finding a bolt!
tardboy21
Woodbridge, NJ
So I bought a second intake for $30. Luckily came with DIS, throttle body and all.
However, I spent the weekend taking parts apart and cleaning it. I removed the secondary flaps and mangled a couple screws pretty bad. I took one to Home Depot to see if I could find others or if I would have to reuse them.
No luck finding new ones.
So today, I went to wash some towels and jeans, (not realizing the small screw was still in my pocket) and threw em in the washer. After the washer ran for 5 minutes I realized what I had done, but it had already disappeared at that point.
Can anyone point me to where I may find some new ones?
tardboy21
Woodbridge, NJ
bump. ^ v ^
anyone? am I up $hits creek here? Going to look at an Ace Hardware and a couple places as well. didn't know if anyone had gotten new ones before or not.
Try sending an email or PM to those with alot of spare SHO parts laying around. NESHO, PA Sho Shop, RCM, maybe the SHO Source guys...
tardboy21
Woodbridge, NJ
Those screws suck...
x2. Looks like I can order them from McMaster. Just good to know the size is M3x.50x5mm.
I will probably get a hex head, that way it should be a little easier to get out next time.
Is it best to use steel vs. stainless?
Also, I shouldn't need locktite should I? Just use that for the main throttle body screws, not the secondaries.
1995SHO9
FLEES ARE COMIN
Carlisle PA
Absolutly loctite it!
One of the guys I've talked to sucked 1 into his engine before.
I used red.....
AREA 91
Area 91
I just bought a bunch of stainless button heads from Fastenall. 100 screws for $14.00:)
I ALWAYS use loc tite on the butterfly screws. You don't want one of those to get sucked into the engine.
hawkeye18
Sorta cares
Norfolk, VA
IIRC, those are M3x.5x10mm. I know they're M3, and I have posted the correct dimensions on here previously as I've gone through this same issue.
And a quick search reveals this... yep, M3x.5. An Ace Hardware store should have them.
