some info on this code please.
ThatShoGuy
michigan
code p1744 has shown up i read somthing about it being tq converter related?
anyone know were i can find a converter and what do they cost if thats so.
bad_4dr_sho
Now what broke
Dickson, TN
Yea I had that code when my torque converter was on its way out. Does the car feel like it fighting you to get up to speed? A stock torque converter is like 250 bucks new. I dont know your finances but I'd tell you, to go through all that work to drop the tranny out of the car, you might want to spend the extra money to send the tranny out to get freshen up as well
ThatShoGuy
michigan
sad thing is the trans has 15k on it,also dont fight to get to speed i noticed the torque converter has trouble locking when cold but once warm it locks decent still notice it aint right.
Don't bother with a stock converter. You can get properly rebuilt ones for under $150 aftermarket. Just be sure they are the dual clutch ones for a SHO.
ThatShoGuy
michigan
so is this the issue converter on its way out?
should i worry that the car will stop drivin?
thanks
ThatShoGuy
michigan
Might be the solenoid. Is the converter locking up?
i feel it locking once it warms but still has issues like it don't like to stay locked, locks hard some times.
trans shifts fine all gears feel fine.
so idk
Check the resistance of the solenoid. Should be 0.98-1.6 ohms.
With an ohm meter check between pin three and the transmission body. This connector is under the intake hose pointing up.
C168 transaxle
ThatShoGuy
michigan
its been so cold out i plan to get out and check this some time today.
what will this tell me? and do i it will the key on or anything?
C168 transaxle
ThatShoGuy
michigan
i was reading over that link you sent me, but i don't think its gonna help me i need something with pics. for help...
were can i find it in the ford service Manuel (pc version)
Well can't say for sure. The .80 ohms you read is below spec. I would assume that that is what needs changed. Even if it isn't the TCC solenoid that is the source of the problem and the problem is the actual TC, the solenoid is bad.
