This scares me.
yamahaSHO
E85 whore
Arkansas
I've seen quite a few cats blown out of SHO's, but never going upstream. When Scott had one going out on his car, he asked me what he should do to fix it. I told him to go beat on the car for a bit, so we did. 10 minutes later, we blew it out the the exhaust and gained a bunch of power back.
Mr Anonymous
Tire Wall
St. Louis, MO
I have personally seen one car that ingested pieces of catalyst back into the cylinders, and know of one other from word-of-mouth (Erik T./RStalveyAFRR).
So, it's not common but can/has happened. It probably takes a very specific set of circumstances.
I certainly wouldn't run around feeling paranoid or worrying about the 1,000,000,000 things that can go wrong with any 14-20 year old car if there weren't any outward signs of trouble.
Vnuk1
Mr. Mayhem
If it worries you that much just replace them, very simple remedy.
1993MTXSHO
Its a Taurus...
Jersey
Just go tap you cats with a hammer or something and see if you hear pieces rattling around, if you do, the cats are toasted and you need to get them off asap. If you don't they're probably fine and you have nothing to worry about.
Brett
SHOs before HOs
Minnesnowta
Ive not been here long, and i recall a very long thread reguarding this, it was argued up and down. It may have been wiped out, but its worth checking into.
ShoBall93
Westfield, Mass
Sooo my Temp guage on my 3.2 is always down way below 1/2 almost most oof the time on the bottom line.. does this mean my Tstat is stuck open? cuz my car is always running funny, can this be why? sometimes feels like its loading up or idling funny or just loss of power?.....
Vnuk1
Mr. Mayhem
Just thinking out loud but maybe it's running rough has something to do with your 72mm MAF? Did you reprogram your MAF for that peticular size MAF? Where can I get one of those powercoated intakes?:rofl:
westcoastclarke
british columbia
yes.
My car was the same way. When the weather got cold, it would not even come off the bottom line. At all. after I changed my tstat the car ran better, warmed up faster, and the temp stayed around the middle even on the highway in the middle of winter. (this summer, when the temp was at 1/2, if i got on the highway it would drop to zero!)
some would say to change ur temp sensor when u do ur tstat. I did not though.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
there's a write up in the first Goody Book on this, that puts it back to, what, 92 or something?? it's been known for some time now.
ShoBall93
Westfield, Mass
72's been off for a bit... It wil be going back in when i get my bored butterflies... haha
Albrainya
New York
if you think the exhaust acts like a "vacuum cleaner" on decel, put your hand an inch from the exhaust pipe and have someone rev it and decel. you will feel constant pressure, even on decel. what a load of crap.
LJRuddy
Pop lock n drop
Poaceae fields
Inbetween the exhaust pulses are moments of vacuum. :wave:
