Brake Upgrade
animex2
T9 Technician
Buffalo
Just trying to make sure im buying the right parts before I get them and find out that I got the wrong stuff.
96+ SHO/G4 Caliper Brackets
94/95 Spindles with ABS holes
94/95 Calipers (any or SHO?)
and 94/95 Bracket bolts, which I can get at autozone for cheap.
Along with the 11.6" Rotors and Brakepads.
the caliper brackets say FN74 on them. If you see a windstar...check those out too, I think they use FN74 brackets...
They will allow you to use the 11.6 disks and pads. If you can't find fn74 brackets, you will still be able to use the 94/95 pads and rotors.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Also, you'll have the use the brackets from an 01+ Gen 4 Taurus. The 00's used 10.9" rotors. Any year Gen 4 Sable will work.
Storm-Chaser
Shit Louis
I've never seen a Windstar with FN74s on them . . . .
Learn to use the Search function from the drop-down menus above. Not only will you find the reference thread, you'll also find threads with pictures/images of the caliper brackets.
Staff online
