SHOForum
Go Back   SHOForum > Help and Maintenance - Gen 1 (89-91) & Gen 2 (92-95) > Gen 1 & 2 - Emergency Issues - Help & Maintenance
Reply
Thread Tools
  #1
Old 03-28-2005, 03:17 AM
SHOtime2511's Avatar
SHOtime2511 SHOtime2511 is offline
CGP
SHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond reputeSHOtime2511 has a reputation beyond repute
Default coolant temp sensor location
i need to know where the coolant temp. sensor is on the car,and also i was
wondering if anyone had any good tips for instalation?? or maybe a diagram?
im planing on replacing the thermostat also
should the CPU be reset after doing such a servace?
is simply reseting the idel via unhooking the battery going to be good enough?
BTW its a 89,i have been reading about the other sensor,the one for the gauge,what would i ask for at the parts store regaurding that sensor
thank you
Brian
__________________
2009 Cheby Corvette ZR-1
2009 Honda Accord V6 MTX
1990 Ford Taurus SHO turbocharged 3.2L
________________________________________
Brian
  #2
Old 03-28-2005, 06:28 AM
Ishodu's Avatar
Ishodu Ishodu is offline
Moderator
Ishodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid oneIshodu is a splendid one
Default
The coolant temp sender for the EEC the "ECT temp sender" is located on the water jacket on the firewall side of the T-stat around the connection for the upper and lower speedo cable. Its a 2 wire sensor. A 1" deep socket will do the job for you. The gauge sender is a one wire sensor just to the front of the T-stat. There pretty straight forward to replace. Just unplug unscrew screw in a new one and plug back in. All you will need to do is remove the neg terminal before you start and reset the idle when your done.
__________________
95 MTX
2011 SHO Convention Best of SHOw and Best Engine and SHOw and Go winner.
3.2 High Comp forged pistons and Custom Cams plus more.
312hp 266tq
Drag Vid
Carbon Fiber or Fiberglass hood with out latch reinforcement or hood pins you and your family could be on borrowed time!
  #3
Old 03-28-2005, 10:25 AM
93_blk_blk_mtx 93_blk_blk_mtx is offline
Registered
93_blk_blk_mtx is on the right road
Default
How do you reset the idle?
  #4
Old 03-28-2005, 03:06 PM
Ishodu's Avatar
Moderator
Default
Quote:
Look in the "How do I section" of the forum. Right above this one on the main listing page.
  #5
Old 03-29-2005, 01:34 AM
CGP
Default
thanks guys i got the part and i'll do it this weekend
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
If you wish to help keep SHOforum running please click the donation button below
Powered by vBulletin® Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Style Provided By: Wrestling Clique - Wrestling Forums
All content Copyright 2000 - 2014, SHOForum.com
This forum is not affiliated with Ford Motor Company
